Fuel Pump dying,...? bout EVAP noid
With the EVAP deleted, would that cause any pressure loss in the system?
Car has 30 psi at idle and once under throttle it drops to 20 real fast, and not even WOT it was at 10ish. So I believe its the pump not the FPR.
Reason I ask about the EVAP is I blocked that line and soon after is when I started having FP issues.
grabbem88
Mar 18, 2015 01:25 PM
