Fuel pump bad?
Old May 22, 2004 | 09:48 PM
Montezuma's Avatar
Fuel pump bad?
I was driveing up to the atm today and being a retard I forgot there was a clutch and killed the motor. Well next time I tryed to start it, it wouldn't start. It would turn over then adventually it idled at about 300rpms. So I got to towed after 45 min of trying. The next day it started right up. Plugs, wires, coil and the fuel filter all have under 4k on them, its still on the original opti though after 96k. So is it the fuel pump?
Old May 23, 2004 | 12:02 AM
Montezuma's Avatar
TTT
Old May 27, 2004 | 08:55 AM
lt1powerd's Avatar
the EXACT same thing just happend to me, i went ahead and got a fuel pressure test and ive only got 2psi haha, im putting in a new walbro pump this monday. I would say its a safe bet that the fuel pump is your problem
Old May 27, 2004 | 09:50 AM
z28marine's Avatar
only way to tell if its your pump...get a fuel pressure gauge and test it....
Old May 27, 2004 | 12:47 PM
CANTONRACER's Avatar
A fuel pump can show correct fuel psi and still be dying.
My fuel pump held 44 psi with vac off idling, 38 psi normal. Revved fine and held fuel psi fine.
As soon as I got on it going down the road, it dropped down to 10 psi...not very good.
Old May 27, 2004 | 01:38 PM
Montezuma's Avatar
I just checked the fuel pressure and it came up to 6psi so that must be it.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
