fuel pump??
Old Feb 24, 2003 | 10:50 PM
allious's Avatar
fuel pump??
car will start with starting fluid and idle briefly, but not rev up. then dies....sound like fuel pump? can i install inline fp and leave in-tank pump in tank, or what should i do
1994 z28
thanks
Old Feb 24, 2003 | 11:07 PM
qwick_trip's Avatar
if your intake pump is bad then you need to replace it. i know jegs and summit has a holley 255L for $160.
Old Feb 24, 2003 | 11:20 PM
Use a test gauge to check the fuel pressure at the schrader valve on the fuel rail. As I understand it, a failed internal pump will not allow you to suck fuel through it with an external pump.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
