fuel pump?
Old Feb 13, 2003 | 06:07 AM
besz28's Avatar
fuel pump?
hey guys car had bad stuttering,missing,replaced opti,new wires,coil runs alot better but still kinda like hiccuping under load,when i run low on fuel it gets very hard to start but finally doeswhat do you guys think? fuel pump?iam gettin a little frustrated if it is do i get the walbro 255? thank you all so very much and have a great day.
Old Feb 13, 2003 | 07:52 AM
doodad's Avatar
If it starts great with a full tank and then gets worse as the tanks gets below about half it is the fuel pump. I have the same problem.
Old Feb 13, 2003 | 08:06 AM
magius231's Avatar
before you buy a $100 pump it would be a good idea to put a $30 fuel pressure gauge on it and see if your actually losing fuel pressure or not. Otherwise your pretty much just guessing.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
