fuel pump....
Old Mar 14, 2010 | 08:58 PM
maroboiiZ28's Avatar
fuel pump....
is my fuel pump out? this are the 3 things i did..
#1 turned key to on, and did not hear fuel pump working.
#2 I also tryed the prime connector straight to battery and got nothing.
#3 i checked fuel pump relay put finger over it, turned key and i felt a click so thats good.....
is their anything else i should check or is my fuel pump put and have to replace it...
if it is the fuel pump i guess its going to be a lonnnng!!! day for me because my exhaust is welded so is ganna be a pain in the butt removing the tank
thnx for help
by the way i have a 94 Camaro Z28 V8 5.7L
Old Mar 14, 2010 | 09:15 PM
6SpdLT1Z's Avatar
thnx for help
Put a fuel gauge on the schrader valve and see how much gas it's getting. Also might want to replace your fuel filter.
You can use this method if you don't want to drop the gas tank.
http://www.fastbird93.com/Installations/Racetronix.htm
CaptainObviousI
29
Apr 29, 2021 10:35 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
tbyrne
Jul 2, 2002 05:37 PM
