Fuel Pump
Old Apr 2, 2005 | 09:09 PM
383TransAm's Avatar
Smile Fuel Pump
I'm just looking at where I should speend my $$$ and was thinking about upgradeing my fuel pump and found this:
http://www.racetronix.com/Racetronix..._Pump_Kit.html
Is this a good Fuel pump?
Would I need the Kit + Harness or just the pump?
Old Apr 2, 2005 | 11:37 PM
slverbullet's Avatar
Re: Fuel Pump
yes, this is a good fuel pump. i use it and i believe many others do as well. the plug'n'play kit is nice. i got it because its a good setup. i dont think that its absolutely necessary though.
Old Apr 3, 2005 | 11:36 AM
383TransAm's Avatar
Re: Fuel Pump
So you don't think I would need this for my setup?
How much HP will a stock fuel pump support.
Acording to my 1/4 mile times from the strip I have around 470HP (I think that is what I figureed) and that is with a 2.4 60ft.
Old Apr 3, 2005 | 01:25 PM
OBE1 95Z28's Avatar
Re: Fuel Pump
Get your car dyno tuned with a wide band O2 sensor. This will tell you if your fuel system can keep up. If you need a bigger pump, Racetronix is the way to go including the plug and play harness.
Old Apr 3, 2005 | 02:22 PM
Re: Fuel Pump
definitely get the pump (or at least i would).
i was saying that i dont believe the Plug'n'play kit is absolutely necessary. it is a very nice kit and i would get it. it includes all new wiring for the new fuel pump, but it is not an absolute have to have in order to run the pump.
Old Apr 3, 2005 | 02:59 PM
383TransAm's Avatar
Re: Fuel Pump
O.k, well I do have a dyno tune coming up on June 18 so I'll see what kind of info I get from that.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
