Fuel Problem
My 1994 Trans Am has been giving me major problems lately. My problem now I believe is fuel related. The car is shaking like crazy at idle, it's burning a lot of fuel through the exhaust, and I was disconnecting all the connectors to the injectors one at a time while the car was running and when I disconnected the #s 2 and 8 injectors the engine idle did not change. This leads me to believe that I have two bad fuel injectors. Also when I connect the Auto X-Ray Scanner it shows that the left injector pulse is approximately 1mS lowere than the right side. Any diagnoses or suggestions would be much appreciated!
