Fuel Pressure WAY too high!
Old Oct 26, 2006 | 02:48 PM
  #16
cjmatt's Avatar
make sure your gauge isnt grounding out. my sender was grounding out on my brake booster and would shoot straight up to 100 psi
Old Oct 26, 2006 | 03:04 PM
  #17
TobyZ28's Avatar
Go back to stock. Nothing wrong with stock ones, and adjust for flow using the PCM .
Old Oct 28, 2006 | 05:13 AM
  #18
Guest47904's Avatar
Guest
I was told when I bought mine a few years ago, they used to look like this:
http://www.jegs.com/webapp/wcs/store...ctDisplayPopup
These were the ones that supposedly had the problem with new fuel on the diphragm. To fix the problem they changed to this style:
However these didn't fit the rails real well and they needed hardware to secure it properly that like mine didn't come in the box with the unit. Blah blah blah.
However what this guy said makes more sense:
Purely because a diaphragm should not move that quickly. You would expect a gradual rise in pressure. Particularly if the vacuum level was not changing. AlSO, If your pressure were changing that much while it was running, the engine would most certainly die from running way too rich. Especially if the pressure were actually changing that fast. Since you didn't mention it dieing, we have to assume it is not and therefore CJMATT is probably correct.
Old Nov 4, 2006 | 11:49 AM
  #19
DetroitGuy83's Avatar
thanks guys....
it was the darn Aeromotive Regulator
Old Nov 5, 2006 | 11:39 PM
  #20
Another one bites the dust!!!
Old Nov 6, 2006 | 01:50 AM
  #21
BlueCamaroZ28's Avatar
Originally Posted by DetroitGuy83
thanks guys....
Which one was it?
or
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
