Fuel Pressure WAY too high!
Old Oct 25, 2006 | 01:24 PM
DetroitGuy83's Avatar
I have a 94 Z28 and just putting it it Run, the fuel pressure shoots to around 40 psi and then either every other attempt, or back-to-back attempts, the pressure shoots straight to 100 psi !!!
I do have a new fuel pump and a new aeromotive regulator (i think this is the culprit)
Can someone please list all the possible causes?
thanks
Old Oct 25, 2006 | 02:00 PM
Sweetred95ta's Avatar
Is this while the car is running or just with the key in the run position (not running)? Why not stick the stock regulator back on there and test it. Unless your injectors are a tad too small or you plan on running FI or N20, then you don't even need an AFPR, IMHO.
Old Oct 25, 2006 | 02:57 PM
HardcoreRM125's Avatar
Ehh, I bet its the regulator. Not much else it can be. Even if the pump "stuck on" or something crazy like that, the regulator should STILL let all the extra pressure out through the return line back into the tank.
I would do what he says, swap your stocker on and see what happens. If that fixes it, send that thing back immediately, and dont even try running it on your car.
Old Oct 25, 2006 | 03:04 PM
The Aeromotive AFPR's have been a problem now for about 5 years. They had someone join CZ28.com and rip me a new butthole when I pointed this problem out a few years ago, blamed the problems on some sort of change in gasoline formulation, and offered anyone a replacement AFPR, no questions asked. Here we are a few years later and here's another problem.
Old Oct 25, 2006 | 03:29 PM
I guess gas formulations must have changed again.
Old Oct 25, 2006 | 05:49 PM
NVetro's Avatar
I bought one within the last year and I am pretty happy with mine on my new 383. Maybe they fixed their engineering issue, which im sure it prob was.
Old Oct 25, 2006 | 08:38 PM
johnny3986's Avatar
I think it is awesome that Aeromotive actually sent someone out after you Injuneer. i think it's even funnier that they used the excuse they did.
I'm with Shoebox on his POV too.
Old Oct 25, 2006 | 08:48 PM
Yea the only real changes in gasoliene in the past 50 years have been:
Change to unleaded
And then more recently ( Like withing 10 years I think) Sunoco began adding a 10% Ethanol to all grades of their gasoliene. Which shouldnt hurt a FPR in any way possible ... WTF ? Will get worse mileage/less power, but barely noticable. Citgo is one of the few who still doesnt use Ethanol in any of its gasoliene, as far as I am aware.
What a rediculous reply. I think its hilarious they came after you on here though.
Old Oct 25, 2006 | 09:40 PM
The guy they sent is still here as a member, but he no longer works for Aeromotive. Told me because I was a "moderator" I didn't have the right to bad-mouth products. I pointed out that it was just my personal observation.
There have been significant changes in gasoline formulation over the past 20 years... it is "possibly" a valid excuse, although a weak one.
Old Oct 25, 2006 | 09:41 PM
TQdrivenws6's Avatar
FWIW I have the Aeromotive 13109 regulator and it works flawlessly. Adjustments are easy to make and the pressures are extremely repeatable even after a considerable amount of time.
Old Oct 26, 2006 | 08:27 AM
Yes, it does shoot up high when driving. The car ran fine for about 2 weeks and then this..... unfortunately i junked my stock regulator.... dumb move!
Now, after reading about what you're saying about aero's product, i don't even think i want to get a replacement from them.....
I guess i'm going back to stock..... are there any good websites where i can find one for a good (cheap) price?
Old Oct 26, 2006 | 08:53 AM
At least get a replacement and sell it.
Old Oct 26, 2006 | 02:27 PM
OBE1 95Z28's Avatar
Nothing let setting up the next guy for failure You must be a firm believer in buyer beware.
Old Oct 26, 2006 | 02:38 PM
I guess.
Old Oct 26, 2006 | 02:43 PM
Yhey dont do cash returns ?
