Fuel Pressure Testing..
Old Oct 2, 2003 | 10:57 AM
ninetythreez's Avatar
what should the fuel pressure be at idle at schroeder valve? 93 Z28 with stock injectors.
Old Oct 2, 2003 | 11:51 AM
GREGG 97Z's Avatar
On my 97 at idle the manual says it should be at 37-38 psi. Before starting it with the key in on position and pump on it should be between 41-47 psi. It may be different for a 93, not sure though. I would pick up a Haynes or similar manual for your car.
Old Oct 2, 2003 | 02:27 PM
93 has different injectors than 97 right? does this make a difference?
Old Oct 2, 2003 | 02:33 PM
GREGG 97Z's Avatar
I beleive the 93's use 22lb/hr injectors, I know the 94-97 uses 24's. I would think the fuel pressure may be different while running but not sure, probably the same with just the key on. Your model year was unique for a lot of things though, best to get the manual for it, and they are only like $15-20.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
