Fuel Pressure Testing..
On my 97 at idle the manual says it should be at 37-38 psi. Before starting it with the key in on position and pump on it should be between 41-47 psi. It may be different for a 93, not sure though. I would pick up a Haynes or similar manual for your car.
I beleive the 93's use 22lb/hr injectors, I know the 94-97 uses 24's. I would think the fuel pressure may be different while running but not sure, probably the same with just the key on. Your model year was unique for a lot of things though, best to get the manual for it, and they are only like $15-20.
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
