Fuel pressure regulator
Old Dec 30, 2003 | 09:05 AM
IslandZ's Avatar
I noticed a fuel smel in the engine compartment of my car and i felt around to see where it was coming from and it turns out the fuel pressure regulator was wet with fuel, this was when the car was cold, and I turned the key to on, to prime the pump. Does this mean my FRP died?
Should I change it to an adjustable FPR, or is it not worth it?
Thanks.
Old Dec 30, 2003 | 10:01 AM
tryintogofast's Avatar
Well as far as whether your regulator is shot I suppose it it a possiblity but it could also be that the O-ring is shot and it's leaking out of there. When it comes to whether the adjustable fuel pressure regulator is worth it, I have one for TPIS.com and I didn't notice any gains as far as HP goes(Think I wasted my money ).The ECU in the car actually compensates for any changes in fuel pressure and I believe the only real way to lean out the car and gain HP is through getting it programmed. Hope I helped
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
