Fuel pressure regulator
Old Nov 3, 2003 | 06:54 PM
ead94z28's Avatar
Could someone tell me how to replace it? Tried search with no luck.
Old Nov 4, 2003 | 11:06 AM
First, remove the vacuum line from the top of the FPR.
Then, release the clamp that holds the two fuel "hardlines" to the intake manifold. As I recall, the Torx screw that holds the clamp is facing down, toward the manifold, making it a bit difficult to get to.
After you release the hard lines, pull off the spring clip that holds the hardline in the side of the FPR. The tube should slide out of the FPR, and if I recall correctly, there should be an o-ring on the end of the tube.
Then use a T-27 bit to remove the single bolt that holds the FPR on the end of the driver's fuel rail. Twist the FPR back and forth slightly and pull back on it to remove it from the rail. There should be an o-ring on the part of the FPR that pushes into the rail, also.
Old Nov 4, 2003 | 01:40 PM
ead94z28's Avatar
As always, very helpful. Thank you.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
