Fuel pressure Question
Old Jun 15, 2003 | 04:30 PM
1BadBrd's Avatar
When you turn your key to the on position, do you get fuel pressure(of course you do) but does it stay at a certain #.
After getting a walbro put in the pressure jumps to 42, but after it primes it falls back to 0 until you try to start the car.
Someone is telling me it is suppose to stay up.
Is it?
Old Jun 15, 2003 | 04:56 PM
slopokrodrigez's Avatar
If you just turn the key to the on position, the pump comes on for like 3 or 4 seconds and then shuts down unless the engine is cranked.
Old Jun 15, 2003 | 04:59 PM
1BadBrd's Avatar
yes i know, but when it shuts off does the pressure fall also?
Old Jun 15, 2003 | 05:59 PM
anaik's Avatar
There is a check valve in the pump that should hold the pressure, except for maybe a couple of pound drop.
Old Jun 15, 2003 | 06:03 PM
Gripenfelter's Avatar
It should stay at around 44psi after its primed. Otherwise your fuel pressure regulator might be screwed.
Old Jun 15, 2003 | 06:06 PM
anaik's Avatar
Pull the vacuum line on the FPR and check for gas.
DirtyDaveW
Dec 1, 2016 05:37 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
dansam
Jul 20, 2002 01:10 PM
