security light will not go off
Old Jun 9, 2003 | 10:15 AM
Fbody1's Avatar
Question security light will not go off
the car is running and the security light is on.were is the box that controls this?cannot find this any were?can any one help?
Old Jun 15, 2003 | 12:01 PM
slopokrodrigez's Avatar
The module is located to the right of the center console near the glove box. Try getting a resistor of the same value as the pellet in your key and put it in the 2 pin connector at the base of the steering wheel (not the yellow connector) Be sure to disconnect it first. This will have the effect of making the module think the key is in and making contact. See if the light goes out. If it doesn't the module is probably bad
Old Jun 15, 2003 | 12:28 PM
camaroz28_97's Avatar
i had the exact problem for months. the car ran fine for about 3 months untill one day the car wouldn't start at all. good thing it was in my driveway it turned out to be the lock on the steering wheel. i got a new one and a new key and everything went back to normal. my advise is fix it now before you get stuck somewhere. it might not be your house
Old Jun 15, 2003 | 06:07 PM
Fbody1's Avatar
thanks guys for the info , is the box silver , I think I seen it , thanks alot
moparman
Mar 5, 2015 08:47 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
JasonD
Jul 15, 2002 02:17 PM
