Fuel pressure issue...pump replacement??
Old Oct 19, 2013 | 10:07 PM
94Zee28's Avatar
My car starting cranking forever before it finally fires and not running well. I changed the fuel filter and I'm only getting about 10-15 psi on the fuel gauge at the rail when the key is on and when I use the prime wire. Once it fires it is only about 20-25 psi while idling. Shouldn't it be about 40-45 when key is on and 43 or 46 when idling? I'm thinking the pump is bad and I plan to do some engine work later on so I figure I will just go ahead and replace it with a 255lph in tank pump. Where is the best place to pick one up and which brand is everyone running?
Thanks!
Old Oct 19, 2013 | 11:11 PM
Re: Fuel pressure issue...pump replacement??
Serious shortage of fuel pressure. Look ar Racetronix for a 255 LPH pump and upgraded wring.
Old Oct 20, 2013 | 08:55 AM
94Zee28's Avatar
Injuneer, can you replace the wiring without dropping the tank?
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
