fuel pressure issue
Old Apr 6, 2010 | 08:24 PM
popstoy's Avatar
fuel pressure issue
how are all of you im having a problem which im 90 percent sure its fuel pump but i would like your opinions.everytime after about 10 min driving car 95 ta bogs hesitates stalls.let it sit for while drives fi ne for 10 min then same thing happens.finally got one code r o2 sensor lean.right away checked fuel pressure everythings fine for 10 min then pressure goes up and down sometimes to 5 psi then shoot right up .i take off fuel regulater vacuum.jumps up normal to like47.then drops to 5psi its a 2 year old walbro 255.it only acts up after about 10 mins running sound like overheating?thanks and i changed fuel filter no change.
Old Apr 6, 2010 | 09:57 PM
Is the fuel pressure reulator "stock", or aftermarket?
Old Apr 7, 2010 | 03:01 PM
popstoy's Avatar
after market forget what make non adjustable no fuel in vac line
Old Apr 7, 2010 | 03:03 PM
popstoy's Avatar
would regulater cause these issues if so i have old one laying around ill try that before i drop tank.
Old Apr 7, 2010 | 08:23 PM
87bandit's Avatar
typically when a regulator goes bad it's the diaphragm being damaging and making the motor dump fuel for no reason.
sounds like a pump, those walbros are pretty hit or miss from my experience.
Old Apr 7, 2010 | 09:14 PM
popstoy's Avatar
update ran car 15 min today to get to hesitate started to buck run rough went to back of car listened to pump i heard go on and off started to squeal like a bad drive belt case closed.for those who want to know the walbro lasted 2 years and 8000 miles but was very quiet.thanks
Old Apr 8, 2010 | 05:23 AM
The Walbro seems to have a questionable reliability. Maybe it just seems like there are a lot of failures because so many people are using them. I have one Bosch "208" pump that is 15 years old, another that is 10 years old, and have never had a problem with either.
Old Apr 8, 2010 | 09:49 AM
87bandit's Avatar
I'm on my 3rd or so walbro in less than 5 years
Old Apr 8, 2010 | 10:55 AM
koolaid_kid's Avatar
Walbros did have an issue with a plastic part from a supplier (so they told me). It failed on mine, and they (sort of, I had to jump through some hoops) replaced it. Also, the Granatellis and Holleys are actually Walbros, just repackaged. If I were to do it again, I would go with a TRE Performance. Half the price, complete installation kit, and a one year warranty. Walbros have no warranty at all.
I have heard great things about the Bosch pumps also.
Old Apr 18, 2010 | 09:37 AM
popstoy's Avatar
update....replaced fuel pump all is good.
Old Apr 18, 2010 | 09:42 AM
What did you use for a replacement pump?
DirtyDaveW
Dec 1, 2016 05:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
