fuel pressure with cam
Old Jul 21, 2004 | 11:51 PM
huskersZ's Avatar
I have a cam with similar numbers as the 224/230, but with a little more lift and duration. On the stock cam, I ran the fuel pressure at 39-39 wide open throttle ie, no vaccum. Is this still ok for the new cam, or do I need more fuel now?
Old Jul 22, 2004 | 03:23 AM
bunker's Avatar
Re: fuel pressure with cam
well at idle you'll autmatically get higher fuel pressure because of the vacume loss with the cam causing your FPR to go richer.
Old Jul 22, 2004 | 04:06 AM
smoknta's Avatar
I've always been told to run what ever pressure the injectors are rated for. If you've got 30lb injectors they will only flow 30lb if the pressure is set for what the manufacture says it should be to flow 30lb. I run mine at 42psi.
Old Jul 22, 2004 | 03:23 PM
No.
The vacuum compensation on the fuel pressure regulator is intended to control the DIFFERENTIAL pressure, not the rail pressure. Your gauge only reads the rail pressure, and that is not the only thing that detemines flow capacity of the injectors. The "pressure" at which the injectors are rated is the DIFFERNCE between the rail pressure and the intake manifold pressure (MAP), when measured on an "absolute" scale.... so... if your rail pressure (what you see on the gauge) rises because there is less intake manifold vacuum (higher MAP), the DIFFERENTIAL pressure between the rail and the intake is held constant, and the flow through the injectors stays constant.... it does not "go richer" because you gauge sees that the rail pressure is higher.
A common misunderstanding.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Cam's maro
Jan 30, 2015 09:21 PM
F(ast)-body
Feb 26, 2003 09:05 AM
