Fuel Pressure
Old Sep 14, 2005 | 08:02 AM
a7293's Avatar
Fuel Pressure
What is stock pressure for a '95 LT1?
Old Sep 14, 2005 | 08:38 AM
redcamaroz28's Avatar
Re: Fuel Pressure
43.5psi
Old Sep 14, 2005 | 09:47 AM
anaik's Avatar
Re: Fuel Pressure
Stock fuel pressure can be between 41-47 psi. For instance mine was 42 psi. The injectors are rated at 43.5. The PCM compensates for the differances, detected by the 02 sensors, by narrowing or widening the pulse widths of the injectors.
Old Sep 14, 2005 | 09:53 AM
OBE1 95Z28's Avatar
Re: Fuel Pressure
The stock pressure of 41 - 47 psi is with the vacuum line remove from the fuel pressure regulator.
Old Sep 14, 2005 | 10:23 AM
anaik's Avatar
Re: Fuel Pressure
oops, correct
Old Sep 14, 2005 | 01:02 PM
DontMixWithRice's Avatar
Re: Fuel Pressure
damn...you guys are good.
if you are looking to replace the pump...get a walbro...its worth the extra $$
Old Sep 15, 2005 | 06:30 PM
a7293's Avatar
Re: Fuel Pressure
Thanks to everyone
Old Sep 15, 2005 | 06:58 PM
96capricemgr's Avatar
Re: Fuel Pressure
If never going past boltons then a stocker will suffice, if looking to really mod the car then a Walbro is a good idea even if you haven't quite gotten to the mods yet.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
