Fuel Pressure
Old Jun 1, 2005 | 03:13 PM
flounder564's Avatar
Fuel Pressure
I Just Found Out That If My Fuel Pressure Is Low That Be Causing My Car To Stumbble And Misfire If It Is Low How Do I Fix It
Old Jun 1, 2005 | 03:16 PM
OBE1 95Z28's Avatar
Re: Fuel Pressure
Could be due to a clogged fuel filter. The stock regulator is not adjustable; it would need to be replaced.
Old Jun 1, 2005 | 03:19 PM
Re: Fuel Pressure
I've Already Changed The Fuel Filter Whats The Next Step
Old Jun 1, 2005 | 03:22 PM
OBE1 95Z28's Avatar
Re: Fuel Pressure
I assume you measured your fuel pressure with a gauge connected to the fuel rail schrader valve...what was the reading with the vacuum line (to the fuel pressure regulator) unplugged?
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
