How hard to change a head?
Old Jun 1, 2005 | 11:53 AM
93lt1supercar's Avatar
I have to change the head on my 93 Z28. The passenger side one. How hard is it really? I take off the manifold, gas system, air system, pop the head off and replace. The head has some messed up header bolt threads which prevent the header from fully resting against the side of the head thusly causing an exhaust leak. I need to replace the whole head. That also begs the question if the 93 heads are different than other years.
Old Jun 1, 2005 | 11:55 AM
1996camarors's Avatar
Re: How hard to change a head?
I believe the heads are the same.
Skill level 6/10
time consuming 7/10
Old Jun 1, 2005 | 03:38 PM
ZMAN Z28's Avatar
Check Shoebox's website http://shbox.com/1/plug_thread_repair.jpg . I know it is for the plug thread repair, so I am not sure if you can do something like this for a header bolt thread repair. Worst case you could take it to a machine shop and they could reair it for you. I don't think they would chare that much for thread repair. As far as pulling the head, it's not that hard. If you have power tools, it doesn't take that long either.
Z
HectorM52
Jul 30, 2017 11:46 AM
parkers Z28
Mar 11, 2016 08:14 PM
blac94Z
Feb 18, 2015 11:36 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
