fuel pressure?
Old May 21, 2004 | 12:32 PM
camaro9402's Avatar
fuel pressure?
hey i have a 94 z28 and i just changed the fuel pump,regulator, and the filter. now when i start the car it will start then die a couple seconds later. checked the pressure with key on not running and nothing start it and it will read like 20 or lower. any ideas on what to check or what to do
adam
Old May 21, 2004 | 02:30 PM
camaro9402's Avatar
anyone have any ideas?
Old May 21, 2004 | 03:53 PM
OBE1 95Z28's Avatar
Cycle the key a couple of times (without trying to start it) and see if the fuel pressure build up (should be closer to 36 - 40 psi). Also check to see if it bleeds down quickly. If it bleeds down quickly you have an issue with:
the internal check valve in the fuel pump
leaking fuel pressure regulator
leak in the fuel line system
The car won't start/run with only 20 psi of fuel pressure.
Old May 21, 2004 | 04:16 PM
ltwonz's Avatar
I'm a buddy of Adam's and we have replaced the pressure regulator, fuel filter, and just installed a 255 pump. I also hooked up my auto xray and it seems as if everything is checking out ok. Yet the car wants to run for about a minute and then starve itself and die.
Old May 22, 2004 | 12:25 AM
ltwonz's Avatar
Anyone have any idea what else could cause the car to run out of fuel like it is?
Old May 22, 2004 | 11:26 AM
camaro9402's Avatar
anyone have any more ideas i need to get this thing running
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
