Fuel Pressure
Old Feb 22, 2004 | 09:01 PM
BC94Formula's Avatar
Fuel Pressure
Just checked fuel pressure after odd stumble at different rpm's when getting into the throttle somewhat. With the key turned to on it was right at 40. At idle it was at 35-36. This is the first time the stumble happened but I have not checked the pressure before this so I dont know if it was ever any different. Any advice appreciated.
Old Feb 22, 2004 | 09:10 PM
ead94z28's Avatar
Stock is 37-38 at idle. You're a tad low, but not too bad. See how long it will hold pressure with the engine off. Prime it then let it sit. It should hold for a while.
Old Feb 22, 2004 | 10:03 PM
what happens if it doesnt....havent had a chance to try...but just in case?
Old Feb 22, 2004 | 10:14 PM
ead94z28's Avatar
Then you might have a leaky injector or a bad fuel pump check valve, to name a couple.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
