fuel pressure?
Old Apr 8, 2003 | 11:03 AM
ericz28w's Avatar
Question fuel pressure?
what is the normal psi for my car?
thanks
Old Apr 8, 2003 | 11:20 AM
Turn the key on, don't start the engine: 43.5psi, +/-2.5psi, so 41-46psi is OK
Start the engine, pull the vacuum line off the FPR: 41-46psi
Engine running, replace vacuum line: 35-38psi (can be higher if you live at a high elevation, or if you have a radical cam with little vacuum at idle.)
WOT: Pressure should return to the "no-vacuum" value, and stay there.
As you drive: Pressure will fluctuate between the values with the vacuum line off and on, depending on throttle movement (vacuum)
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
