Fuel lines?
Old Sep 13, 2004 | 07:57 PM
eagleknight97's Avatar
Fuel lines?
Why did GM locate the Fuel Lines where they did? Why couldnt they have routed them along the firewall and then to the fuel rail? I think the engine bay would look much cleaner if that was done. Can it be done or is that not possible? Thanks!
Old Sep 14, 2004 | 12:59 PM
Re: Fuel lines?
Come on! I know someone knows why they did this
Old Sep 14, 2004 | 01:03 PM
ibanez6rg's Avatar
Re: Fuel lines?
Probably the safest way to route them.
Old Sep 14, 2004 | 06:26 PM
Re: Fuel lines?
Sure you can relocate them.... but I wouldn't put "plastic" any place hotter than where GM put it. There are reports of fires caused when the plastic lines have fallen out of a broken support ring and landed on the AIR connection.
I have dual -6AN braided S/S lines for supply and return, running to the back of the engine/fuel rails from near the front subframe. Looks cleaner, although I still have the EEC vent line in the stock location. But is a costly conversion.
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
