fuel line ??
Old Sep 24, 2003 | 11:46 PM
SiDeWaYZz28's Avatar
Talking fuel line ??
what is the diameter of our stock fuel line?mine broke off so imma change it . .im plainning on getting a flexible fuel line out of jegs and i was wonderin if i got alittle bigger diameter line will it help out performence??
Old Sep 24, 2003 | 11:54 PM
whatsdo ya think
Old Sep 24, 2003 | 11:55 PM
RamAir95TA's Avatar
Bigger lines won't help performance at all.
Take your broken line and measure it.
Old Sep 25, 2003 | 10:08 AM
The stock plastic fuel supply line is approximately 3/8" diameter, the return line is about 5/16". You should actually measure them, because they are not "exactly" those dimensions. These lines will support huge HP... I run -6AN supply and return lines and they are roughly equivalent to 3/8" OD tubing. The setup has supported 800flywheelHP on fuel-hungry nitrous.
How do you plan to attach your new tubing to the system?
Old Sep 25, 2003 | 11:45 AM
run it the same way as stock . . ima just rig up some good looking clips
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
