What should the GAP on my plugs be?
Getting NGK TR55, should I get the .50 or .35 gapped plugs?
Also, are those wire sleeves really that effective? They say they protect them up to 500 degrees. Anyone use them?
Oh yea, I have a Bolt on 95 TA with MSD 6AL ignition
Nah, you DON'T want .50" gapped plugs, that would be about this far: / /
You want the .050" gapped plugs.
Sleeves can't hurt anything, and will definitely help keep the heat out. But I doubt you can put the heat sleeves over the entire length of each wire if you're following the stock wiring route, it's too tight in there.
Originally posted by 95BlackTA
Ok cool thanks guys...I actaully have teh Taylor over the valve cover wires. They also make a sleeve that withstands up to 1000 degrees it said too. I didnt order them though.
You don't buy the gap. You check the gap and adjust accordingly. And use a plug gapper and wire gauge.
Plugs generally come pre-gapped, but not always accurate or the gap that you need.JMHO
