fuel issue
Old Jul 9, 2009 | 06:48 PM
Drew24's Avatar
fuel issue
Ok I'm having a problem. After my car gets heated up which doesn't take long cause I live in vegas and its always like 110 degrees. There is a humming noise comming from the fuel filter I'm guessing. And to make it stop I have to take off the gas cap and let out all the pressure in the gas tank. There is so much pressure in the tank that it takes like two min for all to get out. Any suggestions on what could be causing it. I know this seems like a stupid question but I'm stumped.
Old Jul 9, 2009 | 06:53 PM
The pressure in the fuel tank is controlled by a valve in the EVAP system. Sounds like the pressure control valve is not working, and/or your EVAP canister may be plugged up.
Courtesy of Shoebox:
http://shbox.com/1/evap_system.jpg
Old Jul 9, 2009 | 11:40 PM
Drew24's Avatar
Thanks that would make sense but wouldn't you think it would throw a code if its a emmision issue
grabbem88
Apr 16, 2015 06:57 PM
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Alex Barnes
Jan 24, 2015 10:21 PM
