fuel filter change?
Old Jun 27, 2003 | 12:01 PM
z28marine's Avatar
fuel filter change?
Ive put about 15,000 mies on my car since ive bought it and havnt changed the fuel filter once. And, im not sure when it was changed before that. Ive heard alot of good things about changing it on this board. I was just wondering how long it would take or if i should even do it?
Old Jun 27, 2003 | 12:04 PM
Buttercup's Avatar
I think it's good, easy, and cheap preventative maintenance. Pick yourself up an AC Delco filter and swap it. Very easy job. Since I think it's been described here recently I won't go into details, just do a search.
Old Jun 27, 2003 | 01:32 PM
96 WS6's Avatar
It's a little silver cylinder box thingamaggigy on the floorpan under the rear driver's side... Just get under there with a catch pan and you'll figure out the connectors on the inlet and outlet of the filter.
One important thing, don't forget your matchbook! Key part of the install right there
Okay it was a joke so scratch that I'm not trying to get sued hehe.
Old Jun 27, 2003 | 01:45 PM
CDN WS6's Avatar
I did it yesterday, takes about 5-10 minutes and is very simple.
Old Jun 27, 2003 | 01:55 PM
FacelessZ's Avatar
Cars with 50k miles (+) need to look into a new fuel filter if it hasn't already been changed. A new fuel filter will take away that hesitation....
Old Jun 29, 2003 | 12:58 AM
fbird95's Avatar
Use a catch pan and be patient, and you should end up with no fuel covering you or the ground.
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
Jul 4, 2005 05:00 PM
