fuel filter
Old Jul 2, 2016 | 11:17 AM
frankrizz's Avatar
fuel filter
Hey Members,
I would like to fit my Lt1 with the proper fuel filter. I am currently using a universal in-line type, but I am not sure I am getting the
correct fuel flow. I can locate a stock filter from the local parts store, but it
has a special inlet which looks like a female flare connection for the fuel line.
I am currently using just rubber hose connections. What is the proper hard
line connection at this end? Thanks.
Old Jul 2, 2016 | 11:39 AM
Re: fuel filter
Why not check the fuel pressure under full engine load, to determine if the fuel flow is adequate?
The inlet to the stock filter is a GM "quick-connect". The filter will come with a plastic pinch clip that is required to hold the end of the stock black nylon line in the filter. Right column on Shoebox's guide:
http://shbox.com/1/quick_connect.jpg
Outlet of the stock filter will have a threaded connection to the stock metal hard line.
Old Jul 2, 2016 | 12:37 PM
Re: fuel filter
4th Gen LT1 F-body Fuel Filter Replacement
Old Jul 2, 2016 | 01:42 PM
frankrizz's Avatar
Re: fuel filter
I don't have the stock metal hard line with that male fitting. All I have is the stock metal line with a rubber hose connection. Do you know what the correct size fitting is for the stock hard line?
Old Jul 2, 2016 | 02:39 PM
Re: fuel filter
Since you're working with a non-stock chassis, I would consider using -AN fittings with braided SS lines. I have a fully braided SS fuel system, with an SX Billet fuel filter, good for 1,000 HP, in the stock position. -6AN line is more than adequate.
Z28Freak86
Apr 30, 2024 05:37 PM
1troyd23
Jul 17, 2015 09:11 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
mike24
Aug 7, 2002 10:06 PM
Chris Ja
Aug 1, 2002 07:30 PM
