Fuel
Old Mar 11, 2004 | 07:35 PM
Timboz28's Avatar
Fuel
Is premium fuel a must in the Z?
Old Mar 11, 2004 | 07:37 PM
Terran2k's Avatar
no. it'll run on 87, but you'll lose performance. I'd use 91 -94 octane alwaysif at all possible. I'd only use less if Im almost flat broke with enough money to buy 1 gallon of 87with my tank on E... my friend ran his on 87 and it really seemed down on power.
Old Mar 11, 2004 | 11:38 PM
OBE1 95Z28's Avatar
I wouldn't use anything less than 91. You'll get pre-ignition which will cause the knock sensor to pull timing killing your power. If the PCM can't pull enough timing, you're headed for busted ring lands.
Old Mar 12, 2004 | 12:04 AM
Red96Lt1's Avatar
I actually noticed getting better gas mileage using 93 because timing wasn't being pulled.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
2001CamaroGuy
Apr 5, 2006 10:56 PM
tbyrne
Jul 2, 2002 05:37 PM
