Fuel
no. it'll run on 87, but you'll lose performance. I'd use 91 -94 octane alwaysif at all possible. I'd only use less if Im almost flat broke with enough money to buy 1 gallon of 87with my tank on E... my friend ran his on 87 and it really seemed down on power.
I wouldn't use anything less than 91. You'll get pre-ignition which will cause the knock sensor to pull timing killing your power. If the PCM can't pull enough timing, you're headed for busted ring lands.
charchri4
Apr 14, 2015 06:40 PM
2001CamaroGuy
Apr 5, 2006 10:56 PM
