Front crank seal on LT1...
Old Aug 20, 2004 | 07:35 PM
CR32SR's Avatar
Hey all, question for you:
The front crank seal, is it (easily) externally replaceable on my '95 LT1?
Thanks!
Old Aug 20, 2004 | 07:42 PM
12SCNDZ's Avatar
Re: Front crank seal on LT1...
Yes...The hardest part is getting the damper/hub assembly off. Make sure you set your arrow on the damper at 12 o'clock, so you know where it goes back on, because there is no keyway in the hub.
Frank
Old Aug 20, 2004 | 07:46 PM
CR32SR's Avatar
Awesome, thanks a lot...Now I can get rid of that annoying oil sweat...
Cheers
Old Aug 20, 2004 | 07:47 PM
CR32SR's Avatar
One more question... Is there an o-ring or anything else that needs to get changed when I do the seal?
Old Aug 20, 2004 | 07:54 PM
Spinner's Avatar
Nope. Seal on, seal off.
Old Aug 20, 2004 | 08:17 PM
CR32SR's Avatar
Cool Re: Front crank seal on LT1...
You guys rule.
HectorM52
Jul 30, 2017 11:46 AM
BigWil
Mar 29, 2015 12:24 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
1LEThumper
Jul 14, 2003 12:45 PM
