Found worn Cam bearing when doing cam swap, now what?
Old Jun 16, 2003 | 07:01 PM
  #16
bunker's Avatar
The other bearings look good, I checked with a flash light, this one was worn on the bottom because the timing chain pulls down on it.
Now I need to figure out how to put it back in, trust me this one had to be changed. Plus I asked a bunch of guys who had the same thing, & it always was just the front one when they did their rebuilds.
Old Jun 16, 2003 | 07:27 PM
  #17
Blk94Z28LT1's Avatar
mine had a little brass showing too, not to worried about it. Most small block front cam bearing look like this.
Old Jun 16, 2003 | 07:29 PM
  #18
bunker's Avatar
well I made a removal tool & it came out like a charm, why not replace it? It definetly helps, you know what happens when a cam starts to walk??? bad things.
Old Jun 16, 2003 | 07:50 PM
  #19
If your old bearing is not out of round, use it to tap the new bearing in. Better make sure it is square. You stop when the oil hole is lined up (I thought you said you knew how to do this )
Old Jun 16, 2003 | 08:06 PM
  #20
bunker's Avatar
Yeah I know I just don't want to say I know how then noone replies I want to make sure though 100% even though I made sure when the old bearing was in that it lined up etc.. thanx though anyways
I did it on Aircraft engines, who knows if there might of been something special I would of missed out, again thanx.
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
HuJass
18
Jun 24, 2002 09:19 PM
