Found a solution to the EGR problems.
Old May 12, 2005 | 08:03 PM
LT1 POWR's Avatar
I think i found a solution to the EGR problems. I got a P400 code which is EGR flow malfunction. What i did was took out the EGR valve, sprayed it with some carb/chock cleaner and brushed off the carbon deposits. Reinstalled it, you might need a new gasket. I think they were like $10. Reconected the vacum line and thats it. I took it out for a 30 min drive at all different speeds, mostly above 70, and that seemed to fix it. I havent gotten any codes so far. Hope this works for you guys.
http://shbox.com/1/oil_pressure_sensor.jpg
Its the black roundish thing, it has 2 bolts 13mm i think.
http://shbox.com/1/egr1.jpg
http://shbox.com/1/op_sensor.jpg
http://shbox.com/ci/AIR.jpg
Old May 12, 2005 | 08:15 PM
v8pwrdz28's Avatar
Re: Found a solution to the EGR problems.
or delete it lol
Knightscrapper
Feb 4, 2016 10:25 AM
cmsmith
Apr 11, 2015 09:37 PM
sseeya
Apr 9, 2015 06:38 AM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
HuJass
18
Jun 24, 2002 09:19 PM
