Found out why I can't hook. Need advice
Old Sep 7, 2003 | 02:01 AM
Gripenfelter's Avatar
I lined up with 4 Fbody guys today and my rear won't bounce even one inch.
You could bounce the rear end on the other cars 3-4 inches!!
I have urethan bushings in my rear sway bar with WS6 springs.
I have a set of HAL 12 way adjustable shocks sitting in the basement.
Should I just put them in and set them to a very soft setting or should I get softer springs or??
Old Sep 7, 2003 | 02:09 AM
Geezer powered's Avatar
I like the adjustable shock idea.This way for normal driving you can have it set firm for good handleing adn soft for the drag strip
Old Sep 7, 2003 | 07:48 AM
You will be able to push the rear of the car down with the Hals, even with stock springs. The rears are so easy to put on, I am surprised you have not done it yet.
Old Sep 7, 2003 | 12:25 PM
Been a really busy summer.
Gonna do them in 10 mins.
What should I set the HALs to if my suspension is super stiff Rob? 3? 4?
Old Sep 7, 2003 | 12:29 PM
That's a good place to start for normal driving. You will want softer for the track. Since there is not a lot of weight in the back, the higher settings get very stiff.
Old Sep 7, 2003 | 02:00 PM
Thanx dude.
Old Sep 7, 2003 | 04:15 PM
Grover's Avatar
I have my rear shocks set at 5 and it's not bad. Any stiffer and the rear gets really bouncy going down the road.
MDZ28
Exhaust System
Apr 29, 2015 07:44 PM
cmsmith
Apr 11, 2015 09:37 PM
cmyname1
Feb 16, 2015 08:33 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
HuJass
18
Jun 24, 2002 09:19 PM
