Found out the hard way EveReady batteries need longer terminal bolts.
Old 04-14-2019, 01:36 PM
cardo0's Avatar
So I let the Sam's club tire tech replace my battery. The EverReady was the cheapest battery they had and installation was free. It took over a half hour for the tech to do it and I had to wonder why. I found out last night when the camaro wouldn't start. Car went completely dead. Used a battery tester and battery voltage was a little low but load tested OK. Wiggled the battery leads and the negative was loose. Inspection looked like the battery threads where completely striped but found the threads were in deeper with the EverReady battery. Used a makeshift 3/8" bolt with a 3/8" nut for a spacer to get the cable terminal to tighten up. Found nearly every parts store carries Long Battery Bolts. Never knew that.
Man every time a new fault rises up I start to think of the "donate your vehicle" commercials make good sense. I just don't have an hour every week to keep this beast rolling. I like it and have fun with it but it takes to much time from my other hobbies. Have a new opti that need to go in and if that doesn't work out the car may have to go. Just don't have the time and space for a chronic fixer.
cardo0 is offline
Old 04-17-2019, 06:03 PM
94Z28LS1toLT1's Avatar
Re: Found out the hard way EveReady batteries need longer terminal bolts.
Are you from Las Vegas man
94Z28LS1toLT1 is offline
sweet z
09-11-2006 09:52 PM
Luke 96 T/A
12-14-2004 08:07 PM
Buffy
V6 Tech
18
03-28-2004 04:09 PM
ThotYouKnew
09-06-2003 11:40 AM
sleeperZragtop
06-02-2003 09:33 PM
Quick Reply: Found out the hard way EveReady batteries need longer terminal bolts.
