Found oil leak....
Found oil leak....
I wiped everything down...I thought it possibly was the valve covers so I swapped on another set I had and went out for a drive...I drove maybe an 1/8 of a mile and sure enough the car was pouring out oil again...
I got under took a look and it was all around the oil filter area and up...so I took a rag wiped the valve cover and nothing....behind intake....and oil...fresh oil, I then took a look at the firewall and there was oil splattered and even some RTV that was used!
Back off comes the intake....I DONT want to have to do this again!!!
Re: Found oil leak....
luckily my pressure sender thing came a bit loose-
no intake leaks
my advice-
dremel a slit into the block and a matchig one into the inake. then RTV it and it makes a "wall"
no intake leaks
my advice-
Magenta_Hearts
Mar 29, 2017 08:54 PM
cmsmith
Apr 11, 2015 09:37 PM
HuJass
18
Jun 24, 2002 09:19 PM
