Found oil leak....
Old May 8, 2003 | 07:58 PM
96z's Avatar
96z
Found oil leak....
I wiped everything down...I thought it possibly was the valve covers so I swapped on another set I had and went out for a drive...I drove maybe an 1/8 of a mile and sure enough the car was pouring out oil again...
I got under took a look and it was all around the oil filter area and up...so I took a rag wiped the valve cover and nothing....behind intake....and oil...fresh oil, I then took a look at the firewall and there was oil splattered and even some RTV that was used!
Back off comes the intake....I DONT want to have to do this again!!!
Old May 8, 2003 | 08:03 PM
chasmanz28's Avatar
Re: Found oil leak....
i hear you i lucked out doing my intake gasket for the first time 3 weeks ago and havent had a problem yet, i do know if its not done right you will get leaks like in your case, i hope you fix it this time
Old May 8, 2003 | 08:04 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
luckily my pressure sender thing came a bit loose-
no intake leaks
my advice-
dremel a slit into the block and a matchig one into the inake. then RTV it and it makes a "wall"
Magenta_Hearts
Mar 29, 2017 08:54 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
cmsmith
Apr 11, 2015 09:37 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
HuJass
18
Jun 24, 2002 09:19 PM
