Flywheel balancing question
Old Apr 15, 2007 | 07:56 PM
93BlackTA's Avatar
I have a 93 LT1 M6 and my engine is internally balanced so i have a ATI Damper thats neutrally balanced and i was told i need a neutral balanced flywheel....some ppl have said to take the stock flywheel and grind the weights off them....the problem i'm having is the stock flywheel/flexplate doesn't seem to have any weights added....it seems like its all one part with a ring gear cast into it for the starter....its pretty heavy also and doesn't look like a normal thin flywheel...can someone help me please? Oh yeah, I tried searching but i need a answer pretty quick...Thanks
Old Apr 15, 2007 | 08:37 PM
jonesy's Avatar
the stock flywheel is zero balanced
Old Apr 15, 2007 | 11:21 PM
Stock LT1 is externally balanced at the rear, using a weight on the flywheel (M6) or flexplate (A4).
Even if you found the weights, I wouldn't just grind them off and assume its now neutral balanced. Take the flywheel to a shop and have it neutral balanced.
Old Nov 9, 2021 | 07:07 PM
Nick P's Avatar
Re: Flywheel balancing question
On the flywheel should it have a weight going across the top from hole to hole on the side that says engine side. I'm lost to what flexplate to get I'm being told to get internally balanced. But all parts store houses have a weighted flexplate on 1 side.
Old Nov 9, 2021 | 09:34 PM
https://www.camaroz28.com/forums/lt1...xplate-889193/
Rij1
Oct 7, 2012 11:57 PM
lawmanz28
Oct 17, 2009 11:26 PM
dannyum89
Mar 4, 2007 12:42 PM
94_camm
Oct 18, 2006 09:59 AM
93black-ta
May 15, 2005 11:14 PM
