you think this is balanced
Old Oct 17, 2006 | 02:20 PM
94_camm's Avatar
Ok so i got my motor back from the machin shop and noticed it didnt have the flywheel on it.so if they balanced the bottom end and wen i go to put my flywheel on it will throw it off.crank is inturnal balanced.(383 lt1)
Old Oct 17, 2006 | 02:23 PM
97WS6SCharged's Avatar
Re: you think this is balanced
Use a flywheel with no weight on it and you should be ok.
Old Oct 17, 2006 | 02:27 PM
94_camm's Avatar
how do i know is thiers a weight on it?
Old Oct 17, 2006 | 02:38 PM
WS Sick's Avatar
Lokk at a stock flywheel or flexplate , the added weight welded on sticks out like a sore thumb. Ask your machinist if he balanced it with a weighted flywheel or a neutral fly and go from there.
Old Oct 17, 2006 | 03:42 PM
94_camm's Avatar
i called him b4 n hes said sumthing bout neutral
Old Oct 17, 2006 | 05:21 PM
SS RRR's Avatar
If it's neutral or internally balanced you will have to get a flywheel that is zero balanced. Stock LT1's are internally balaned in the front and externally blanced in the rear using the flywheel.
Old Oct 18, 2006 | 08:48 AM
WS Sick's Avatar
If all else fails you can take a stock one , have the weight removed and have it neutral balanced.
Old Oct 18, 2006 | 08:50 AM
94_camm's Avatar
wat if i buy an aluminum flywheel?
Old Oct 18, 2006 | 08:58 AM
WS Sick's Avatar
Make sure it is neutral balanced, if not have it balanced. (machine shop)
Old Oct 18, 2006 | 09:59 AM
94_camm's Avatar
thanks alot!
Jeff1904
Jun 5, 2016 05:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
karpetcm
Aug 14, 2015 03:02 PM
bunker
Aug 1, 2015 10:10 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
