Fluidampr Questions
Old Aug 17, 2003 | 09:15 PM
thewinner's Avatar
Fluidampr Questions
Does this come internally balanced to the lt1? It already has a "keyway" in it correct? A place for the key to go in, i know the crank has a keyway in it but no key.
A blower pulley can still be piggybacked onto this right?
Old Aug 17, 2003 | 10:09 PM
LPEdave's Avatar
Re: Fluidampr Questions
It's neutrally balanced in that there's no specific balancing done. Just like your damper is under normal circumstances. Yes, it has a keyway, but my guess is that just like the hub, you probably could use it w/o the key. I used a key.
Uh no, I don't think so.
Dave
Old Aug 17, 2003 | 10:16 PM
thewinner's Avatar
what are the blower guys doing for an SFI damper? i thought LJ had a pic of one on his site, but the side navigation on his page is not working for me!
Old Aug 17, 2003 | 10:23 PM
LPEdave's Avatar
Hmmm.. his site works for me. Looks like an ATI damper - http://para.noid.org/~lj/1000hp/images/BeltOn.jpg
Dave
Old Aug 17, 2003 | 10:56 PM
thewinner's Avatar
exact pic that i had seen before.looks like the pulley is welded onto the damper? maybe LJ will chime in or ill send him an email
Old Aug 18, 2003 | 12:52 AM
Both George Baxter and Madman used the ATI Super Damper with blower pullies. Both of them broke the billet hub that came with the ATI. If you are looking at a really large blower, you need to double key the crank (it can be done with the crank in the car!!) and the damper hub, and put a band around the outside of the damper hub to strengthen it. Not sure how the Fluidampr hub compares to the ATI.
Old Aug 18, 2003 | 09:38 AM
LPEdave's Avatar
I don't remember LJ every breaking that hub, but so much of his stuff is custom he may just have had a custom piece to start with. The Fluidampr doesn't have all those holes around the damper pulley - looks like maybe the ATI was made to allow a blower pulley to be bolted on?
I wouldn't wait for LJ to read this thread, I'm not sure he spends much/any time here.
Dave
Old Aug 18, 2003 | 10:54 AM
Gripenfelter's Avatar
I have a Fluidamper on my 383 and I only drive it in the summer.
I wouldn't recommend it to anyone that winter drives their car.
Reason being, Fluidampers have a fluid inside them that only provides max vibration protection when its warmed up.
There was a post last year in the Advanced Tech section from a guy that snapped his crank because he started up the car on a cold March spring morning and within 2 mins he was racing and shifting at 6000rpm.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
