fitting 1.6rr and valve coverswith alternator?
Old Sep 14, 2003 | 06:31 PM
Supermanx500's Avatar
How do I put 1.6rr and valve covers to fit with or without moving alternator?? My mechanic said that I have to move the alternator? do I? What do I need to make this set up work?
Old Sep 14, 2003 | 06:48 PM
Transamdriver's Avatar
As I said on Bhamracing.com you will need to cut the supports in the stock valve covers or go with a set of the LT4 valve covers. Do a search on here it has been discussed hundreds of times.
Old Sep 14, 2003 | 06:53 PM
joeSS97's Avatar
What he^said.
Old Sep 14, 2003 | 07:26 PM
Bud M's Avatar
Your mechanic is wrong, reuse the stock valve covers. Grind on the supports so they will fit between the roller rockers.
Old Sep 14, 2003 | 07:34 PM
12SCNDZ's Avatar
Or, you can use the GM Performance aluminum covers. I had to do a little "creative clearancing" on the back of my alternator, but it wasn't any big deal.
here's some pictures of them on my engine.
http://www.geocities.com/max_wylde/built_pass.jpg
http://www.geocities.com/max_wylde/b...ivers_side.jpg
If those links don't work, check my web page
http://www.geocities.com/max_wylde/12SCNDZ.html
Click on the top 2 pictures on the left hand side
Frank
All-Trans Transmissions
Old Sep 14, 2003 | 07:53 PM
jim88iroc305's Avatar
Frank
I used the ProForm tall aluminum covers and just ground the alternator until it fit. There are valve covers that are already notched here http://www.flatlanderracing.com/index.html
go to valve covers - Pro Line - Aluminum
Old Sep 14, 2003 | 08:00 PM
12SCNDZ's Avatar
LOL...Yea, but they don't have a Bowtie, and say CHEVROLET, like mine do.
Mine were only $170, chromed aluminum.
Frank
Old Sep 14, 2003 | 08:13 PM
Frank
mine were had for $120.10
part # 12497978
polished aluminum with red bowtie and Chevrolet inlaid in black.
here's what they look like
http://www.salleechevrolet.com/Profo...ve_covers.html
Old Sep 14, 2003 | 08:20 PM
12SCNDZ's Avatar
part # 12497978
They're the same ones I've got, except mine are chromed. Oh, and I painted my bowtie purple
Frank
Old Sep 14, 2003 | 10:29 PM
Smoke T/A's Avatar
What rockers are you using???? If they are SA then you will not have to cut or grind any thing. If they are NSA then yes you will have to cut the supports on the covers. Either way if you want to take the covers off the alternator will have to be removed.
Later
Joe
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
