First Dyno pull but 5* pulled knock retard
Old Oct 21, 2006 | 01:16 PM
RickS's Avatar
Last week i had my first dyno pull she put down 296rwhp 330rwtq 429rwhp and 562rwt on the 150shot
I believe the tune i have is off on timing, Using a tech 2 i just ran it and discovered its getting 5* of spark retard at wot upper rpms 4-6Krpm how much power am i loosing?
heres my graph
Old Oct 21, 2006 | 02:03 PM
Re: First Dyno pull but 5* pulled knock retard
When did you get the 5* knock retard - NA, N2O or both?
Its leaning out a bit above 5,000rpm NA.
Old Oct 21, 2006 | 02:48 PM
RickS's Avatar
off the n2o its pulling 5*, i dont know whats going on with the spray.
Old Oct 21, 2006 | 05:08 PM
blackz97's Avatar
Looks like a dry shot to me he might just be running out of fuel on whatever injectors he has.
Steve
Old Oct 21, 2006 | 08:10 PM
RE AND CHERYL's Avatar
Actually it looks way rich on the juice after the ECM reacts to the extra air. I personally don't like dry shots. Look how lean it gets before the ECm catches up.
Re'
Old Oct 22, 2006 | 02:51 PM
RickS's Avatar
nah its a wet kit, i guess the lean out was due to the air purging out of the fuel lines while the spray was on
just changed jets to 150 before that pull
Old Oct 22, 2006 | 11:01 PM
Look at the red line for the NA pull..... the A/F ratio is around 13.0:1, and then starts climbing to 13.6:1 as the RPM goes up.
TitoPR221
May 26, 2015 12:20 AM
BLK1997Z28
May 7, 2015 03:01 PM
BigWil
Mar 29, 2015 12:24 PM
maybe2fast
Mar 16, 2015 11:59 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
