Firebird headlights?
Old Mar 12, 2004 | 10:31 PM
calfirebird's Avatar
Angry Firebird headlights?
Ok my car was broken into and the alarm went off so they cust the Red wire that goes to the little red Junction block on the firewall. Now i put the wire on temp so i could start and drive the car home. Well when i did this the the head light wont come up and they are on all the time. But very dim, the alt is charging good also. I checked all the fuses and relays for a blown one. Has any one ever heard of this, or know what i can check? Any help would be greatly appriciated
Cal
Old Mar 13, 2004 | 12:52 PM
No one has ever heard of this? I put the cable on good now and the headlight motors just sit there and click when there down. They dont come on if you turn the switch. Im running out of things to look at if your have any susgestions please post for me?
cal
Old Mar 13, 2004 | 01:09 PM
T/A#4's Avatar
Take it to a dealer.
Try resetting the PCM by disconnecting your pos. battery cable, otherwise your screwed !
Old Mar 13, 2004 | 09:20 PM
Brent94Z's Avatar
Super Moderator
Typically when a headlight comes on but doesn't come it, it means that the raise/lower arm shaft is on the wrong side of the stop. This can happen when you pull the raise/lower arm shaft off to do the 180 rotate trick or install brass gears. But, since it sounds like you just got in your car and it did this, I'm mystified
You could check the headlight control module. That is the only thing I can think of that is common to both headlights and would prevent the doors from opening even when the lights are on. Make sure you have a good connection there and at your headlight motors. Check for corrosion in the motor connectors too... that sometimes causes the motor to not work but usually only one goes out when this happens.
Formula Steve
Sep 19, 2023 08:31 AM
David Dempsey
Mar 12, 2016 12:42 AM
karpetcm
Sep 29, 2015 10:08 AM
Greg88
Sep 20, 2015 07:14 PM
jackpawt883
Sep 10, 2015 08:53 PM
