Fire from the coil, No fire to the plugs HELP
Old 07-13-2005, 07:42 AM
PUGHBOY's Avatar
I have a 94 Formula. I t has been running fine, no sign of any trouble. Starts with just a bump of the ignition. I pulled the battery out to put in my boat over the weekend because the battery in the boat was dead and didnt want to go to the parts store. I had just driven the car about 12 miles 5 minutes before I pulled the battery. Today I put the battery back in the car and it wont start. It has fuel. No blown fuses.It is putting fire out from the coil but no fire to the plugs.I replaced the cover and rotor to the opti about 25k miles ago to the vented version while changing wires and plugs.I was unable to get underneath the car. I am going to have to pull it in the shop so I can jack it up, but does anyone have an idea what it could be.
PUGHBOY is offline
Old 07-13-2005, 07:55 AM
Re: Fire from the coil, No fire to the plugs HELP
If there is spark going into the opti and none coming out, it is probably the rotor.
shoebox is offline
Old 07-13-2005, 08:20 AM
BlownF1's Avatar
Check the battery connections again...since that's what you messed with last. Poor connections happen alot and are easily overlooked. You might be seeing some spark at the coil, but not enough.
BlownF1 is offline
Old 07-13-2005, 08:47 AM
Gripenfelter's Avatar
Make sure the coil wire clicks when you plug it into the opti or at least its in right all the way.
Otherwise I would guess rotor as well.
Gripenfelter is offline
Old 07-13-2005, 11:26 PM
PUGHBOY's Avatar
I was testing with a multimeter. The coil is putting out the correct voltage and wires are good. Got the car in my shop and jacked her up. No fire out of opti and connections are good. My guess is the rotor also right now. Its just strange it gave no signs of any trouble before I shut the engine off, and then not fire when I go back to start it. Is the MSD unit the best choice. I see JEGS is selling those now? I may as well replace the opti and an electric water pump while I'm at it
PUGHBOY is offline
Old 07-13-2005, 11:32 PM
30696bird's Avatar
I've seen some post that said the MSD opti cap and rotor is NOT out yet......I don't know if it's true but that's what I've seen. I would get a new opti from Dal if I were you. (that's what I did ) New GM opti's have a warranty................something you WILL want.
30696bird is offline
Old 07-14-2005, 07:51 AM
MSD has not shipped their cap/rotor kit to resellers.
shoebox is offline
Old 07-14-2005, 08:31 AM
MPZ28's Avatar
My opti did the same shi*. Thats why we call it the opticrap!
MPZ28 is offline
daves91z28
3rd Gen / L98 Engine Tech
05-12-2016 06:19 AM
ad356
04-11-2015 11:12 PM
grabbem88
03-18-2015 01:25 PM
IRABuss
09-07-2011 09:08 PM
Redbird
08-18-2002 02:48 PM
Quick Reply: Fire from the coil, No fire to the plugs HELP
