Fire from the coil, No fire to the plugs HELP
Old Jul 13, 2005 | 07:42 AM
PUGHBOY's Avatar
I have a 94 Formula. I t has been running fine, no sign of any trouble. Starts with just a bump of the ignition. I pulled the battery out to put in my boat over the weekend because the battery in the boat was dead and didnt want to go to the parts store. I had just driven the car about 12 miles 5 minutes before I pulled the battery. Today I put the battery back in the car and it wont start. It has fuel. No blown fuses.It is putting fire out from the coil but no fire to the plugs.I replaced the cover and rotor to the opti about 25k miles ago to the vented version while changing wires and plugs.I was unable to get underneath the car. I am going to have to pull it in the shop so I can jack it up, but does anyone have an idea what it could be.
Old Jul 13, 2005 | 07:55 AM
Re: Fire from the coil, No fire to the plugs HELP
If there is spark going into the opti and none coming out, it is probably the rotor.
Old Jul 13, 2005 | 08:20 AM
BlownF1's Avatar
Check the battery connections again...since that's what you messed with last. Poor connections happen alot and are easily overlooked. You might be seeing some spark at the coil, but not enough.
Old Jul 13, 2005 | 08:47 AM
Gripenfelter's Avatar
Make sure the coil wire clicks when you plug it into the opti or at least its in right all the way.
Otherwise I would guess rotor as well.
Old Jul 13, 2005 | 11:26 PM
PUGHBOY's Avatar
I was testing with a multimeter. The coil is putting out the correct voltage and wires are good. Got the car in my shop and jacked her up. No fire out of opti and connections are good. My guess is the rotor also right now. Its just strange it gave no signs of any trouble before I shut the engine off, and then not fire when I go back to start it. Is the MSD unit the best choice. I see JEGS is selling those now? I may as well replace the opti and an electric water pump while I'm at it
Old Jul 13, 2005 | 11:32 PM
30696bird's Avatar
I've seen some post that said the MSD opti cap and rotor is NOT out yet......I don't know if it's true but that's what I've seen. I would get a new opti from Dal if I were you. (that's what I did ) New GM opti's have a warranty................something you WILL want.
Old Jul 14, 2005 | 07:51 AM
MSD has not shipped their cap/rotor kit to resellers.
Old Jul 14, 2005 | 08:31 AM
MPZ28's Avatar
My opti did the same shi*. Thats why we call it the opticrap!
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
ad356
Apr 11, 2015 11:12 PM
grabbem88
Mar 18, 2015 01:25 PM
IRABuss
Sep 7, 2011 09:08 PM
Redbird
Aug 18, 2002 02:48 PM
