finding the cause of a dtc p0174
Old Nov 22, 2010 | 02:59 PM
  #31
Guest47904's Avatar
Guest
Make a whole bunch of back pressure to find the leak
If it was a leak, wouldn't it show up if you block the exit of the exhaust?
Old Nov 22, 2010 | 04:10 PM
  #32
REDLT4's Avatar
Re: Make a whole bunch of back pressure to find the leak
I'm not entirely sure the cause is an exhaust leak, but it makes sense. This code has also been know to be caused by vacuum leaks, but what could be leaking that only affects bank 2?
Old Nov 22, 2010 | 05:27 PM
  #33
Guest47904's Avatar
Guest
Re: finding the cause of a dtc p0174
I think it's control. Not a leak. Do the paperclip trick.
Old Nov 22, 2010 | 05:43 PM
  #34
REDLT4's Avatar
You mean check the wiring for problems? Wouldn't the readings from the O2 be intermittent if there was a problem?
Old Nov 22, 2010 | 09:13 PM
  #35
95TA04GOAT's Avatar
If the o2 sensor or an exhaust leak were the cause of your lean code it would be running rich while still setting a false lean code. So it should be dumping in a whole bunch of extra fuel. Are you experiencing rich running symptoms? A raw fuel smell from the exhaust, black smoke etc?
I'd still lean towards a vacuum leak. Monitor the short and long term fuel trim for bank 2 while spraying either carb cleaner or using one of those small propane bottles near the passenger side(bank 2) of the intake near the gaskets and other fittings. If you spray in one area and the short term fuel trims move towards zero significantly you've found the source of your leak. Keep in mind the fuel trims aren't instant, it might be delayed a second or two.
Old Nov 23, 2010 | 05:54 AM
  #36
Guest47904's Avatar
Guest
NO.
They could merely be sluggish or hover near one end of the readings.
Let me ask you something. You say the O2s both swing like they should and yet one bank is severely lean compared to the other. Yes?
Does the control stay in closed loop the entire time or does it jump back and forth from closed to open and back again?
What happens when you force it into open loop?
Old Nov 23, 2010 | 01:28 PM
  #37
REDLT4's Avatar
Originally Posted by speedygonzales
NO.
Bank 2 is running near the edge of actually setting a code for the lean condition, I wouldn't call it severe, just enough to set the code.
I have no indication of a problem other than the code, no performance issues, no black exhaust.
I've only scanned it during closed loop(I think) with the engine up to temp. How would one know if the PCM is switching back and forth? Also how would one force open loop? Unplug the MAF?
Old Nov 23, 2010 | 07:06 PM
  #38
Guest47904's Avatar
Guest
A scanner such as those from Snap-on indicate when you go in and out of closed loop. As that is all I use, I can't speak for others. I did have a wiring issue on my OBDI and it would go in and out of closed loop.
To force it into open loop all the time, merely unplug one of the front O2s. It will set a code eventually but it will put into open loop control. It would be interesting to see what the O2s see once it is in open loop. Even though the PCM ignores their readings.
Old Nov 24, 2010 | 05:44 AM
  #39
Guest47904's Avatar
Guest
Are the air pump check valves closing all the way?
Old Nov 24, 2010 | 09:21 AM
  #40
bw_hunter's Avatar
That's an easy one to spot..the rubber/plastic tubes attached to it melt away if they don't......
Old Nov 25, 2010 | 09:54 AM
  #41
REDLT4's Avatar
I haven't had time to troublshoot further, however, I have checked the AIR valves to ensure one way operation, and they are good.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
timmy39120
May 8, 2015 11:41 AM
lt1matt
Mar 21, 2015 07:35 PM
mattstrike
Mar 11, 2015 07:33 PM
dreamer1q
Aug 20, 2002 11:19 AM
