Finally got my new 383 setup on the dyno
Old Mar 1, 2006 | 11:36 AM
  #16
LT193's Avatar
Re: Finally got my new 383 setup on the dyno
Weight is the only reason we need more power lol. What mods u got on ur lightning?
Old Mar 1, 2006 | 11:58 AM
  #17
J Rod's Avatar
Not too shabby at all! I think I have about the same goals in mind as you. I want to make as close to 400 rwhp as possible without sacrificing drivability/reliability. As of right now, I've got stock heads on my 383 with a 227/232 cam. I'm still trying to decide on a head/cam combo but I've got plenty of time to make a decision seeing as how I have no $$. If you don't mind me asking, what are the specs on your cam? I saw Lloyd said 220's, if so then maybe I won't need a bigger cam after all. Guess it depends on the heads I go with, eh? What do those LE1's flow anyway? Also, have you checked your gas milage at all? Just curious as to how fuel efficient that setup is.
Old Mar 1, 2006 | 12:15 PM
  #18
CANTONRACER's Avatar
Ported blower, 4lb lower pulley, phelonic spacer, shift kit, custom tune, cai
Under $1400 in mods....
The instant you mash it you got 500+ rwtq and it does not drop much.
Old Mar 1, 2006 | 12:47 PM
  #19
jmzlt1's Avatar
I'm sure the torque must feel great in that car. Another thumbs up for Lloyd's packages. I can't wait to get the 383 in the Monte finished. Heck, I'm even thinking about swapping out my 218/230 cam for one of Lloyd's cams.
Old Mar 1, 2006 | 08:39 PM
  #20
cehan's Avatar
I don't want to reveal all Lloyd's proprietary information, but if you check out his website, you'll see his power estimates for the different head/cam packages. I'd say his advertised numbers are conservative. It's more than just the cam by itself. When I talked to Lloyd about doing a LE1 383, he worked with Bret Bauer to design a cam/spring setup that would work with his ported heads, and he even called Chad Golen to ask about the short block that he was building for me. He put in a lot of effort to make sure it all performed well together. I couldn't be happier with the results.
Old Mar 2, 2006 | 08:17 AM
  #21
kirk94z's Avatar
hey nice numbers, i was thinking about going with exactly the same set up. is your car a a4, and how was the customer service from both companys. did the heads bolt right up n u were ready to go? thanks
-kirk
Old Mar 2, 2006 | 09:10 AM
  #22
Javier97Z28's Avatar
Moderator
-kirk
Customer service from Lloyd is unparalleled.
Old Mar 2, 2006 | 01:31 PM
  #23
SStrokerAce's Avatar
Dam good numbers. I'm suprised how well that cam works on a 383. I always consider that cam the red headed step child because it's not really a big numbers cam (no 400+rwhp) but it really should perform on the street and track since it just makes lots and lots of TQ.
Bret
Old Mar 2, 2006 | 06:56 PM
  #24
cehan's Avatar
Bret
To me, the torque is incredible. Considering that I have a new set of MT ET Street Drag Radials, when I nail it in 1st gear from around 3000 RPM, the front jumps up and the car just leaps forward, and I can feel the rear just barely breaking traction . Not that it matters, but someone asked about the gas milage. I didn't actually check it, but when I was ******* it around for 400 miles just to break in the new clutch, it seemed to get about the same milage as I got when I had the Hot Cam. This is the perfect street package, what a fun car to drive! Good job on the cam, Bret
Old Mar 3, 2006 | 12:37 AM
  #25
johnny3986's Avatar
Probably somthing to do w/ a eaton blower, and some massive torque... oh and a Automatic as well..
just maybe!!
Old Mar 6, 2006 | 05:56 PM
  #26
kirk94z's Avatar
this a a4 or a m6 sorry if i missed it. i am looking to go with the same set up.. i got a a4 so if u had a a4 i would be happy with this set up
Old Mar 7, 2006 | 08:15 AM
  #27
cehan's Avatar
It's an M6
Old Mar 7, 2006 | 09:12 AM
  #28
RealQuick's Avatar
There is a stroker for ya folks. I made 383rwhp/353rwtq with heads and cam...but this car would probably trap 5mph more then mine did due to the insane torque! Nice #'s. BTW, I trapped 114mph wit only 368rwhp/336rwtq (tune wasnt even close compared to the 383rwhp/353rwtq #'s).
Old Mar 7, 2006 | 02:46 PM
  #29
IllusionalTA's Avatar
A4 would be insane w/ that torque and a good converter...
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
TitoPR221
May 26, 2015 12:20 AM
C6LS3
Apr 15, 2015 09:50 AM
madman69
Aug 18, 2002 03:58 PM
