FINALLY found what my problem is...can I fix it myself?
Old Sep 25, 2007 | 12:07 PM
  #16
raroz28's Avatar
use a stethoscope to determine if the injector is really dead. Put a stethoscope or long screw driver on the injector, then your ear on the other end. It should click.
If it doesn't, give it a light tap and see if it clicks then.
Fuel injectors take about 15 minutes.
It's 4 bolts on the fuel rail. Remove them, and pull the entire rail with injectors off and lay it upside down to keep gas from spilling. Be sure the car has sat for a while to relive pressure.
Oil the o rings going into the rail so they slide in easy. I've done it 5 times in the past couple months because of an injector problem.
Old Sep 25, 2007 | 12:58 PM
  #17
Brandon94Z28's Avatar
I would pull the fuel rail up and slide a small bowl or something under the so called bad injector, turn the key to prime and see if fuel comes out of it.
Brandon
Old Sep 25, 2007 | 01:49 PM
  #18
ricehammer's Avatar
If you need a set of stock injectors PM me. I have the set that came out of my 96Z (boxed up) from when I did my mods at 54k miles.
Old Sep 25, 2007 | 09:15 PM
  #19
96ZCamaro's Avatar
You should put an osciliscope (sp?) on a good injector to see what it reads. Then put it on your bad one and see if it is getting the same signal. If not then you might have a wireing problem.
Old Sep 25, 2007 | 09:50 PM
  #20
micfly83's Avatar
Well the problem has gotten progressivly worse over time
When it first started happening it was barely noticeable, and then it just got worse and worse until now it seems like its running just on 7 cylinders.
This leads me to believe that its the actual injector just going bad vs an electrical problem.
Old Sep 26, 2007 | 11:06 AM
  #21
micfly83's Avatar
So the Hanes manual has failed me once again
Theres nothing in there about injector replacement
and everyone keeps saying to be clean about it and take your time, so I assume theres some difficulty to it
Any writeups on the internet, or something else to look for in the index of the book that will bring me to the fuel injectors
or maybe your own tips
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
ChrisFrez
Dec 7, 2014 06:01 PM
squarehead
Nov 21, 2014 08:02 PM
guionM
69
Nov 30, 2006 02:01 PM
HuJass
18
Jun 24, 2002 09:19 PM
